Inventables Community Forum
Is this cable suitable for XController/NEMA23?
I’ve got an X-controller to run a workbee frame with NEMA23 steppers. Trying to track down some decent cable to run to them- how does this look?
https://www.digikey.co.nz/product-detail/en/alpha-wire/2424C-SL010/216-2424CSL010-DS-ND/12471144
18AWG, foil shield… am I missing anything? Cable selection seems to be a little limited here in NZ unfortunately, but this sounds like the right stuff?
@BradTipper
18AWG shielded should be just fine. Connect the shield to DC ground on the controller side only.
Thanks, will do! Much appreciated.
I always use 16 gauge wire, but 18 should be OK.
