Issue with X carve not cutting the same depth
Hi i am very new to the world of the X carve
i recently purchased my 1000mm x carve version it was second hand, but i am having an issue where the machine will not cut at the same depths depending where the router is on the work space.
i am at a loss of what could be the issue everything seems to be tight i have added a couple of pictures so it is easyer to understand what i mean.
Kind Regards
Adam
Probably uneven height of the waste board and/or uneven thickness of material being carved.
Hello and welcome Adam,
Searching for “waste board” resulted in multiple threads. I will point you in this direction: How to test that my x carve is cutting at the same level
There could be other factors at play here, but a good starting point.
Good luck.
My thoughts exactly.
