Firstly Thanks Larry…next for the gcode challenged and those of us that just want to laser engrave pretty pictures…is there a Really simple explanation of not only setting the new grbl update up (I mean Mickey Mouse type illustrations) and having just purchased my laser, also confused by the wiring to the driver control. On the Jtech site they call for the spindle control wires and the 24v spindle wires to be soldered together. I ain’t connecting till I get the OK from you guys with perhaps another photo. Please…
Regards
Mike
Here are the instructions for wiring the J-Tech laser to the X-Carve’s controller.
Here is the driver instruction manual.
Thanks for this. Are you able to tell me if I need to connect my arduino logic control wires to the 24v spindle wires and then to the jtech driver?
Answer is in the other thread.
It’s the same Pin 11 & ground that passes through from the UNO to the gshield stepper driver. That should be the same connection that turns the spindle on/off with the PWM to a relay. It seems there should be a switch from using the laser or your spindle with the same PWM control, but you can try it without one.
So my question is: within Easel, is there a way to tell the program that you’re now in laser mode and it would respond not unlike the spindle controls? Are we there yet?
If not, then it would be a nice feature. Click button, it’s a laser. Click a button, it’s a spindle.
I’m pretty sure that Easel does not have that capability.
If you use PicSender it has buttons to switch between modes.
How do you currently use the Makita in regards to turning it on and off (manual or SSR using PWM as trigger, other)? And what program do you use to send G-code to your machine?
I manually start Makita , its not connected to the Arduino control box at all.
Ive been using PicSender for Laser and previously UGS for carving
I have just installed a linear Z-axis and as I press $H the Z rises 10mm and halts , console saying “home position now set”
the Z motor was disconnected and longer wires soldered on during install. i had better dbl chk all wiring is good, Ill go back and RTFM
No.
With your change to the Z axis you will have to calibrate your new setup. ( $102 grbl parameter ).
Re above posts homing fail
Well I had one of those photographic memory moments , but with the lens cap on !
my homing went pearshaped ,
I hadn’t done anything except put the new z axis on.
As soon as I presssed home it moved 10 mm , got a fail alarm .
So I went through all the GRBL settings , sat at that screen nearly all day trying to invert every setting I could to make it work
In desperation I went to my phone to look at the pictures I took prior to dismantling the Z , and sure enough , I had put 1 wire on the Z limit switch on the wrong terminal ,
if theres a moral to this story , its if you have an issue , always go back to the last thing you changed, in this case it was me wiring up the Z limit,
what did you use to send this?
@LarryM, is there any plan to update grbl 1.1f. My understanding is that some of the multimode is built into 1.1f ($32), but the adjustable dell down to 1ms is not. Please advise.
Tim
No plans to update. I don’t recommend 1.1f/g for laser work.
Changing the dwell floor and rate is a compile time option in grbl. If you know how to build grbl from source it is an easy thing to change.
ok, is 1.1e ok for laser work, or is it jjust anything above 1.0c.
I’m a little worried if I go back too far in firmware I’ll break something else.
Is it just a change in config.h as below along with a P0.00x or more involved??
#define DWELL_TIME_STEP 50 // Integer (1-255) (milliseconds)
The only “official” grbl release that supports laser work is 1.1f/g
I don’t recommend it because in the implementation of laser mode they modify the way some of the G-code commands work.
I have a version of 1.0c that implements laser support that does not require calling programs to be modified to use the new feature (laser support).
If 1.1f/g changes don’t bother you, then use version 1.1f/g to build your version of that release.
It’s been a while since I built my version, but I believe that is correct.
I don’t think LightBurn supports 1.0c
I think it does support 1.1f/g.
I don’t recommend 1.1f/g for laser work, but it’s fine for spindle work.
If you do run 1.1f/g it has special rules for laser work.
