The post processor is a text file. Most likely the M05 is in the HEADER section. You can remove it from there and then you should be ok.
Got it, that worked!!
I downloaded this PostP from the jtec web site. I wounder if anyone else is having this problem?
Thanks Larry!
I just changed the post processor on the website as well. That was an oversight on our part in the code. Thanks for finding the error and sorry you had problems!
Best Regards,
Jay
Just a follow up: Everything has been running flawlessly!!
This is a little dated, but I was hoping you could tell em which of the two GRBL post processors listed I should use? I don’t understand why there is a “Z” and a “no Z” option. Is the difference for engraving on 2d vs 3d items? Meaning if on 3d the focal length will change along the path of the model, and the Z is then required to move with it to stay in focus?
