Jeremys 3d depthmap software
Software that converts a greyscale heightmap image to STL
Release output paths · jeremysimmons/heightmap2stl-gui · GitHub
do you like the software? :beer: buy me a beer ($5) via paypal :beer:
2018-02-19
version 1.3.4
output path for STL file now supports Program, Source File or Custom
thanks @JasonCavanaugh for testing
Can you help me out on the install?
Download the ZIP from the Github page (big green button).
Extract.
Run the .jar file.
Thank you Neil for the informative info.
There’s no JAR file. It’s an EXE.
@BrandonTaber My instructions are now outdated. The .jar I mentioned can be run from a CLI. Jeremy updated his original link which now takes you to the executable…download and run. Looks like you can drag and drop images now. Easy.
@JeremySimmons Awesome work! I’m sure it will help a lot of people.
@JeremySimmons, Hi Jeremy, When trying to run heightmap2stl-gui release I get a JAVA cannot be found. Download/Install from https://java.com error. I have the latest version of java. Any help would be greatly appreciated. Thanks
What directory is java installed to?
Have you added that directory to your PATH environment variable?
Sigh. I blame myself for not finishing the rewrite of this in .net. Having to rely on java was always dumb…
Hi Jeremy, It’s located
C:\Program Files (x86)\Java\jre1.8.0_161\bin
In a command window
echo %PATH% | clip
Paste as a reply
do you have this file?
C:\ProgramData\Oracle\Java\javapath\java.exe
Jeremy,
I downloaded your program but it wont work for me.
(100% sure its something that I’m doing wrong)
Do you have instructions available?
What type of file does it work with?
Hi Jeremy, I uninstalled Java then reinstalled and now it’s working. Thanks!!!
@SeanNaylor Heightmap - Wikipedia
Save the heightmap file from the wiki page
load the file into my tool, run it
Load the generated stl into vcarve
Generate roughing toolpath
Generate finish toolpath
Send the toolpath to your CNC
When I try to run the exe file a window tries to pop up and disappears. Any help please? I’m obviously not real computer literate.
Are you downloading the GUI version from here?
yes, I am
ah wait, I got something with your link. Now I just got to figure out the application
