A little project with a lot of problem, but finally the result is not so bad
Problems :
- The top tend to bend so the top and the bottom are not well aligned.
- The bending create a difference of depth for the inlay so the white wood is not on top of the black wood, That can be sanded but that will be more difficult.
- I think the feeding was too high for the bottom so the cut of the outside square was not straight, so I loose some mm on the outside border to correct that.
I’m still waiting for the hardware bought on http://www.leevalley.com and I have to sand the top. I will update the pictures when it’s finished.
