JTech Laser extender
Hello All
For some reason I am obsessed the Jtech laser but like the thumb focus I thought this may be of use to others . This is a work in process but the idea is to be able to move the laser up and down with out using the z axis
laserslide1.stl (8.1 KB)
i would love to disagree with you but you speaketh the truth , just made out of laziness really I can slide it closer to the board with out having to take out the bit
Used to engrave items that will not fit in the X-carve. Remove the waste board and place the X-carve on top of the item. Lower the laser and blast away.
Ahhh ok now that does make sense,thanks for the tip
