How are you setting up Easel to cut a groove around a rectangle cutting board? I would like to add one for the juice that runs off but i don’t know the best way to include that into my plans. Thanks in advance.
-Charles
-Charles
Use a bowl bit, tell Easel to run along path (centered)
A bowl bit? I am having the same issue. I have a 1/2 inch round nose bit and it shows nothing in the preview, so it won’t carve. Is the trick setting it to carve centered?
