Check out the setting for $2. In Easel, go to MACHINE/ADVANCED/Machine Inspector. You’ll see the window to type into the console.
This correction can also be made in the set up directions with the" test your wiring" portion.
I think he’d want $3.
Probably easier just to swap the Y motor connectors at the controller.
@Zvonimir, make sure your machine is off when you plug and unplug motors.
You are correct there Neil, though the chart was in with the $2 setting information and used for $3 as well. I had to use this chart with UGS when the internet wasn’t making it’s way to my machine.
It is more likely that it will be done through the set up procedure I linked to, which many of us used initially to set up the x controller.
I’m having the same issue. I do not see any m5x20 screws. I have M5x8,10,12 and 14 but no 20
