When I do the keyhole generator when it cut it’s not plunging straight down cutting it’s just going back-and-forth what am I doing wrong and how to fix
You must set the depth of cut in the settings the same as in your design. For example, when you go into the app and set the depth, let say .3" of an inch, then you must go to the settings in the top right and go to custom and set the depth of cut to .3" also. It will plunge to the .3 and then move to cut the groove and return to exit out the same entry hole. Good luck @MarkBohler
Thank you I follow your page and learn a lot thank you very much for what you do.
