Keyhole generator problem
When I pull up the keyhole generator the fields don’t appear so I can fill them out.
Hi Larry,
please explain. I have been using the key-hole generator and had a TON of issues at first (still do sometimes if I overlook something). The app is incomplete, and you need to make adjustments to the cut AFTER it is imported. But since there is not enough detail in your question, I’m unsure of the specific issue, so won’t guess.
I am a relative newbie, so not likely the best to answer, only that I made a lit of firewood and dust while learning how to use that app (it is NOT intuitive).
I learned a LOT from Paw Paw’s video - it (the video) is a bit long-winded and could use some editing, but it has proven invaluable to me
Bing Videos
