Anybody successfully used a keyhole router bit to make a keyhole slot using Carvey?
I have seen that gcode, but it is for the xcarve.
interesting. it’s the first time I heard of “Slot Cutter Router Bit”
any links for bits you have used successfully?
I’ve used this one several times to cut slots for hanging some of my signs.
Thanks!! I have been using the direction arrows manually. I’ll be giving this a try first thing.
I just tried it. Twice! Works great.
Yeah, the manual process works but is slow because you have to make the increments so small.
Thanks again.
I have made keyhole tools paths in Fusion 360 and used on the x-carve and my big machine
actually pretty simple to make in fusion or v-carve pro
if you need help with any of those 2 programs I can help
