I’m not completely done yet, but almost there…
I used the box making app inside Easel to make the box and random Icons and shapes from inside Easel to make the cutouts… I have only cut out the box itself and plan on sanding / gluing it up tomorrow after work. I then plan on cutting out the shapes again on 1.5" stock to make them thicker and more like the “real” sorting cube… These will also be cut using an inside cut rather than a on path cut to make them fit easier into the cube… I’m sure someone else has already made one, but i couldn’t find it in the forums / projects…
I will be finishing these all off with a beeswax and mineral oil mixture…
I will publish this to the projects page when i have the thing put together… If anyone wants to make one here is the easel file…
http://easel.inventables.com/projects/5gAice2ZPcntewkVcYbJnw
“real” version
