Not a problem with anything but what is everyones go to machine. I have a 3018 and am concidering something a little bigger and thought i would get some thoughts from the group
How much bigger do you want to go. I had a 3018 then got a X CARVE 1000x1000 love it. But if you want to just a littel bigger you can buy kits to make your 3018 in to a 3040 for about 150 on amazon. Depends on what you want to make
This is the key component…
If you are milling full-sized doors out of solid wood, you would obviously want a really large machine, but if you are only milling 3"x6" Christmas ornaments, a small machine will do just fine.
{:0)
Brandon Parker
Wanted a quicker carve with a bigger bit, better finish.
how big is your spindel now
1/8
do you have ER11 collets if so you can go on amazon and buy a 1/4 inch collet and bit. with that said is your spindle 300 watts or a 500 watts
I will look. 300 watt
You can buy a 500 watt on Amazon for 99 dollers that will speed up your caving
I’ll look into it but I’m in Canada and thinking $350 plus extras but sounds like it’s my answer. Thanks for the help
glad to help
