Hi everyone,
I’m trying to start using a PLH3D 6W FX laser with my X-carve…
I’ve configured and connected my laser as stated on the manual. Power beam is red, Armed beam is red, I updated the easel firmware, GBRL…
So, I enter $32=0
Then M3 S1 and I get “error 9”
My values are:
• $132=100.000
• $131=750.000
• $130=750.000
• $122=50.000
• $121=500.000
• $120=500.000
• $112=500.000
• $111=8000.000
• $110=8000.000
• $102=50.000
• $101=39.830
• $100=39.938
• $32=0
• $31=0
• $30=12000
• $27=1.000
• $26=250
• $25=750.000
• $24=25.000
• $23=3
• $22=1
• $21=0
• $20=0
• $13=0
• $12=0.002
• $11=0.020
• $10=115
• $6=0
• $5=0
• $4=0
• $3=7
• $2=0
• $1=255
• $0=10
I would really appreciate any help, since I’ve been searching in fórums and I can’t seem to find anything about this.
Thanks in advance!!
Can you copy the console log?
I may be wrong but for your laser to work properly with your cnc you need to set $32=1
Thanks for your answer WayneHall,
To test the laser it has to be $32=0
With $32=1 it will only fire the laser if it’s moving to engrave
Thanks!
I entered Machine inspector again and I realized it was on status “alarm”
I moved the y and x position closer into the work table (a couple of mms) and now it’s in idle and actually fired the laser entering the command M3 S1
Oh I feel silly… Thanks everyone for your help!
Stay safe
That’s where I was going…Error 9 means you tried to send gcode when the machine wasn’t idle.
Thanks NeilFerreri1!
I just wrote another issue but suddenly I worked it out! Let’s see if I can get Lightburn working cause its not moving correctly. More reading to do
Bonjour à tous !
J’avais le même problème Que MercedesChilla , j’ai donc modifié comme lui la position
Mais cette fois je n’est plus de message d’erreur , mais le laser ne s’allume pas !!! ( la console me dit : ok )
je ne comprends pas
