So I am using a 60 degree vbit on my first largish test run. I’m using MDF but its coming out pretty good and am wondering a few things:
I know the vbits will leave sort of a stroke as they don’t cut straight down as they are v shaped. Is there a 2nd pass bit I could use to simply remove the stroke and make it vertically straight? Would a 90 degree vbit cause less of a stroke? Here is a video … https://youtu.be/2Wh2s97EREc
On MDF - Cuts easy but it also damages easy, corners etc. What would anyone recommend to help preserve it, toughen it up, etc?
Thanks!
