Does anyone have a Les Paul Full Body DXF or SVG file they can share?
Ken4
December 28, 2022, 10:19pm
#2
think I seen one in projects
SethCNC
December 29, 2022, 6:54am
#3
you may want to use the search feature in this forum. there is an entire topic setup for Luthiers many littered with links to peoples projects…
Hey all,
A local luthier has asked if I could carve the rough stages of a les paul top carve. He currently does this by hand but is looking to save time. I understand plans can be purchased for CNC ready files, but as we’re only roughly contouring the body they aren’t necessary. I have the topography image and know the depths of each layer.
[image]
Initially I was thinking I could export as an .svg and use easel’s fill function do to each layer, however, as the paths need to be joined, this m…
I always use the search here, and I did search for a file, and I’ve seen the example you show below (Les Paul Template v2) and that is not a full body SVG or DXF file, it does not show the cutouts, the channels etc. But thanks for your less than polite response.
Ken4
December 29, 2022, 11:19pm
#5
Kevin,
sorry to hear that, looks like you need to open your wallet and one.
gib.dxf (7.8 MB)
