I have created an engraving project in Easel. The simulator looks good but the words are not lined up as see in the preview.
Is that a 2 stage carve or did you carve it all with 1 bit?
One bit 15 degree v-bit
Did it do the wording last ?
Looks like Y position shifted.
What machine you got and what were your cutting parameters?
No. First
I dont know the 3018-machine but may the 80IPM feed rate be a little on the high side?
Due to the nature of how steppers work, available torque drop at speed and will eventually => zero available torque.
When this point is reached, a stepper will stall even without load applied to it.
Try the same piece with 40IPM but double depth per pass.
How do this work out?
Thanks. I will try this weekend
