Avril
September 3, 2018, 1:16pm
#1
Hi, complete rookie here.
I need to level my waste board as I am unable to cut anything out the depth i’ve set.
I’ve scrolled through to try and find a step by step process but cant find one.
Please share with me how to do this including depth/ plunge rate etc
Also I noticed on Easel the colette trimmer that I have to level the board doesnt show up as a selection I can choose?
Thanks for your help guys
How far out of level is your wasteboard?
Check that your original board relative to Z, adjust for large discrepancy.
Mount a sacrifisical board to your Xcarve waste board
Use a large flat end mill (3/4" are commonly available)
Use the Dewalt at its lowest speed
Draw a rectangle in Easel as large as possible that exceed the size of added board
Set to Fill and under Machine set stepover =80% (default is 40%)
Jog the end mill to the lower left corner, so it is about 1/32" above it.
Run the carve at 50 IPM and total depth = 1/16" This is called a skim cut / skimming your waste board
If the entire surface have been touched you now have a X/Y plane that is level relative to the Z-axis.
If only partial surface have been touched run it again, now 1/32" lower than last time. Continue untill the entire surface have been carved
Avril
September 3, 2018, 1:37pm
#4
Thank you!!!
So I do have my sacrifcial board on top of my wasteboard which has been heavily drilled into in some areas but hopefully will be able to now even it all out.
Avril
#5
No idea, cuts in some areas, doesn’t in others
Excellent advice shown above. Try to correct any major flaws first before skimming
