Limit switch, x, y, and z axis issues after assembly
The Z axis is backwards, the X, axis is backwards, and the Y axis motors spin the same directions essentially twisting the spanning member rather than traveling.
None of my limits switches are working. I have gone through the installation steps multiple times and have confirmed that the wiring has been done correctly.
Any help would be appreciated.
Look back at the assembly instructions, you have to reverse two wires on one of the Y stepper motors to get them to turn in opposite directions.
During machine setup in Easel you can test the motors and change the direction they travel to get axes motion in the correct direction.
Get that working and then we can address the homing/limit switch issues.
Thanks Larry, found my mistake… went through the setup process and it worked the other bugs out.
