I temporarily resolved the issue by replacing the cable connecting the Y limit switch and the G shield, and not running it through the drag chain. I thought putting a small capacitor on the switch would eliminate the noise, and it did, but the voltage was dropped down to about 4.6 from 4.8, which is apparently enough for the Arduino to read the pin as low. A new cable fixed the issue.
For a more permanent fix, I was intending to get new cable that was longer to wire the steppers, use shielded cable for the limit switches, make the cable coming out of the machine longer, and terminate them with XLR connectors that can mate with connectors coming from the electronics. That would also make upgrading to the X Controller easier. I should probably go ahead a pull both Y steppers through, and connect them on the electronics end.
remember the x-carve is based off the shapeoko 2. Here’s your solution for the limit/homing switches. BTW that PDF that was provided up above is wrong. 12 and 11 are switched. click the link for proper instructions.
Im not really sure how it is either butI have mine wired up like the schematic that sketch has as well and my spindle control and limit switches work just fine!!! Thats weird, maybe at some point between SO2 and X CARVE the Arduino change ??lol. Also I had a question, I am tring to extend the length of my Limit switch wiring but no one local to me has 22/2 stranded insulated wire, but they do have 20/2 would this cause any problem if I were to use the larger wire?? If it would then does any one know a good place to get 22/2?
Yep the change is made in the GRBL version that X-Carve came with, which is version 9i. There is a specific hex for the X-Carve as well…
Found here:
I am guessing there is even a specific hex for the 1000mm and both options with Lead screws instead of ACME screws too.
I guess the point I was trying to make is that even though it is based on the Shapeoko 2 and is all the better for it, we can’t make assumptions based on that knowledge. The machine has changed, the firmware has changed, and the software has changed.
Here is a pic I just took of my pin locations for the PWM and Limit Switches and it works great.
Well that’s great to know. I’m glad I put pin connectors on mine so I can swap them out easily. Unfortunately I did not see your picture till just now. I didn’t think of bending the pins to the side for easier access. I’m not going to fuss with trying to resolder though, I’m lucky enough to get the pins in there with good solder at all.
I’m a SO2 up-grader, I have grbl 9.0 I believe. I am continually noticing that the information for the up-graders are completely lacking. From knowing exactly what your getting in the upgrade packages, to the dependencies like this with the software change. I didn’t know the PWM system didn’t come with the spindle upgrade, as there was no description of exactly what was in there at the time, not to mention there was no separate upgrade option in the pick your parts section. Now I have to order another 50 bucks or so for all that and have to wait for all that to actually start doing things I feel like the newb I was when I just got the SO2 all over again.
Thanks for your clarity though and the link to the file. could I get a link to the directory for those files?
That same fellow (Kevin Patterson) has a video on YouTube showing his Shapeoko playing Greensleeves. Makes me a little sad that while I struggle just to keep my machine working, he has time to learn how to make his play music (it is surprisingly good)
I’ve messed around with those Hall sensors before, had intended to use them on the DIY machine I never finished. There’s a great thread over at CNCzone with a lot of wiring, testing, mounting, and tuning information. If I can find my bag of sensors, I may revisit this, because I managed to smash my Z switch yesterday.
Unless you have configured your machine so the switches you have installed are both homing switches and limit switches. The switch is ignored when you are moving an axis and hit the switch. The only time the software pays attention to the switches is when you start the machine and home the 3 axis. Then and only then the software knows where the carrage is located on the machine.
If you want true limit switches that stop movement when one is triggered and you want limit switches on both ends of X and Y You have to wire up 2 more switches and configure them in the software as limit switches.
@DavidSohlstrom is right… They are sold as limit switches and until you set them up as such, it is best to consider them homing sensors and nothing more.
