May be a dumb question, but how do you change the line width using the pen in easel?
Hey Phil…
Not a silly question. I believe its based on the bit size…
I will look ar the offset tool. Thanks. I did try making my line using using a larger bit then combining th line into the drawing then selected a smaller bit size. The line stayed larger than the new smaller bit. A sort of work around. Thanks for all the help.
Ok. Thanks! Did not realize that
