Linksprite with Easel
I connected my linksprite to the Easel software and now my z axis is cutting about half the depth that it previously did. I took it back to the original software where it cut correctly and it is doing the same thing. Is there a reset or command I need to send to it. X and Y are cutting true to dimension.
I am guessing the Linksprite has a different Z screw pitch.
You will need to adjust your steps/mm for the Z
What is the command line for that?
$102
All the info you need is here:
