Hi, I have a Croncraft Large machine and have set the x,y and z as per instructions.
When I set the carve area it carves at a different location as set and the size is also off.
You’d want to fix the size first then the position will probably also be resolved.
This is how you calibrate the CNC.
This is an X-Carve shown in this video but the process is the same for all grbl machines:
Measure variance, record original values, do some math, enter new value. Re-Test to verify, adjust if needed.
