Where are the dimensions for the Z-Probe button located, just in case I decided to build my own…’
Skip…
Skip…
that would be up to you.
you make it whatever design you want at whatever thickness you need and input that into the advanced parameters dialog. even with the factory puck you should measure and input the information to make sure it is accurate.
P.S. I am assuming by button you mean the puck.
and if this helps here are the factory specs.
