Could it be possible to allow locking the individual values. Example lock X value and this would allow movement on Y axis
Until this feature request might become implemented, you could use one of the options below.
If you hold down the Shift key and move the mouse either up or down, the object should move in only the initially detected direction, or you could manually change the X or Y coordinate individually.
{:0)
Brandon Parker
