I thought I saw an Easel Pro new features video that showed I can set the clearance of the tool path to make sure I don’t hit my clamps. I can’t find this setting.
In Easel ,under Machine, there is a Safety Height setting. I don’t normally use Easel, but I’d assume you could try changing that value and cut some air. I don’t know if that is what you need here though.
I found Safety Height under Machine, General Settings. Thank you!
Depending on the situation, you might also think about changing the “Origin Safety Height” as well.
{:0)
Brandon Parker
Good Day, Instead of using clamps I use woodturners double sided tape
