As a noob, I can’t thank you all enough for your recent guidance and answering of questions. I am looking to convert the attached image for carving. I have only become familiar enough with Inkscape to do a bitmap path trace and invert an image to B&W. Any direction would be appreciated. I recently lost a coworker to Cancer and am looking to make a plaque for the office.
Dave, Give this a try, there is a lot of detail in the bottom of the badge. I attached a picture of what I would use, its a .005 engraving bit to carve the detail. Someone else might have different ideas to help you out. I will attach the Easel file and the SVG in case you need it. Sorry for your loss
I don’t know if I can post the SVG, I would need your email to send you the file Thanks Russell Crawford
What program are you using to convert the images? My mission this winter is to learn V carve pro and Inkscape.
Russell, you are a wizard !!! Thank you. Check your messages.
I use CorelDraw to design in. I used the image that Dave had and converted the top part of the file but found a better image of the bottom part online. CorelDraw is similar to inkscape, it just cost money. I have V Carve on my list of things to get.
mmmm pizza…
