Loose Router Bracket
Good day all,
I have the Xcarve 750 using a DeWalt 611 Router. I have noted my work getting a little sloppy and then noticed that the top of the router carriage is a little loose, maybe a couple of hundreds. I have also noted that on curved cuts the machine emits a low pitched whine when the x axis is moving in conjunction with the y axis. so I have concluded that either I need new rollers for the Z axis rollers or is there an adjustment that can be made to “tighten” this up? thanks in advance for your responses.
Karl
First things to check are that all of your V-wheels are tightened down (securing bolts and nylon lock nuts), then that your V-wheel spacing is adequately set (via the eccentric nuts).
Thank you, that did the trick. Best wishes
Karl
