hello, I tried all the solution above, but still the xcarve lost the connection during the job, never at the spot.
PORT ERROR: Writing to COM port (GetOverlappedResult): Unknown error code 31.
Change USB port (I tried 5 different port (USB2, 3, 3.1).
turn USB port spleeping mode to disable
Used different Gcode sender (easel, open build, transfer).
change USB cable
To date, the issues is still present and I can’t run the job.
Could it be the arc generated by the drawing?
Thanks
Thanks, I just bought another USB cord, and (cross finger) no more problem. Brand new USB are not equal apparently. The USB need to be as short as possible and got a ferite bulb at one end. The one provided with the Xcarve was apparently of very poor quality.
