Catbide Tools.
I donāt know, but Iām pretty sure at least one of those 9 lives will be used up, plus really annoy the cat.
Looks like heās really enjoying his X axis.
@Jason - In case you are wondering what the numbers on the bit case tell you about the bit:
The radius of the tip is 1mm
The cutting length is 1.25" (5/4)
The shank of the tool is 0.25" (1/4)
The overall length of the bit is 3"
HRC55 - High hardness steel
2 flutes (2F)
Thatās probably fine with him because he sees two bowls of food.
Thatās what happens when you buy parts online from a cat-alogue.
Limit one āpurrā customer.
Youāve got to be kitten me
Cool, thanks for the info. Thatās neat!
cat clamps? just use claws?
OUCH!!!
Heās not cross-eyed, he just has a focal point a heckuva lot closer than other cats!
This thread is a meow-ntain of information about why you shouldnāt buy cheap copy cat parts.
Anything less and heās not feline fine.
