Yes, this. Please.
I just broke (another) limit switch by entering a bad command in machine inspector.
I also learned that the limit switches aren’t active in MI, and the Z axis went the opposite way I expected.
I REALLY want a machine control panel that will let me do what I want, in a reasonably safe way.
Some things the panel should offer:
- Jog X/Y/Z as on the Carve panel where you’re setting the start location
- Go Home - return to the last home position.
- Initiate Homing Cycle
- Move a specific distance on the X/Y/Z axis, but within the defined work area and obeying the limit switches.
-Kelly
