Machine running off path after starting Gcode cut
Hi,
I designed a simple cut in VCarve Pro and exported the two paths as GCode for the X-Carve. The design is a back plate in oval shape. The dimensions for the work piece are the same in VCarve and what I set for Easel. I homed the X-Carve after firing up the machine. Opened a new project, set the work piece dimensions and bit. After that I imported the first GCode, and set the XYZ coordinates of the work piece. When I start the first path the machine runs about half an inch off the center upper edge to start carving. I am kind of at my wits end now. Any help is appreciated.
Stefan
Never mind. I figured it out.
