when I used to click on the “machine” tab.
At the bottom, of the window would click on “advanced”
then would see an option to “Generate g-code”
Then an option to “Export g-code”
Now when clicking on “machine” tab, shows "general settings: then “export GCode”.
Is this a change. If so, do I need to download any updates.
Have a Sainsmart 3018 and using free version of Easel…
AND IF you have 2 bits it will look a little different, you can download both files together in a ZIP (yellow arrow) or Download each file separately (red arrows)
