The shield is not a requirement, there is no problem connecting directly to the Arduino.
Convenience is what it provide.
@PhilJohnson thanks for all your great info. I’m almost done with my new controller. I think I’m crazy but I’m doing a ton of upgrades at once. I’m going from 500x500 to 1000x1000, new controller, auto spindle and shop vac control, 3gt belts, nema 17 to nema 23 269oz, … it’s been a lot of fun and I’m sort of OCD so it’s going to look really good too! Thanks and I’ll post more pics when I’m done.
Tell me you’re going to put a nice clear piece of plexiglass over the top so everyone can oogle your wonderful work.
Absolutely! And labels on the buttons and switches!
Oh my!
Hey @PhilJohnson, awesome design! I might make a new controller based on this. I was wondering, have you used 4 x 269 oz NEMA 23 steppers? Do you think I could just them on the X and Z axis and use the original 140 oz ones on the Y axis? (so I’ll have 2 x 140 oz, not sure if it’s equivalent to a 280 oz one).
I don’t really mind buying 2 extra 269 oz steppers, I’m just curious about this.
I am not Phil but:
I use 140oz steppers on Y (dual) and singel 269oz steppers for X and Z. Work very well.
But if you get a good deal on 4x 269’s by all means just go for it
Note that the Xcarve do not accomodate the longer 269oz case without modification.
Thanks for the explanation! I’ll go with 4 x 269 oz then! (the 380oz ones look nice too!).
It means that I’ll have a full set of NEMA23 motors (the original 140oz ones) and a gshield sitting in a drawer… I might get a MiniMill at some point to put them to use , or I’ll start working on making a 3D printer with them.
If you have the Inventables Z axis installed the 269oz-in motor will not fit in the standard position for Z (the new motor is 76mm long).
You can invert the motor and use it with the standard setup, or upgrade your Z axis.
Thanks, I’ve just updated my Z-Axis (with a CNC4Newbie kit) and I’ll soon update my X/Y Axis to lead screws (thanks to @Phantomm upgrade kit!), so I should be fine with longer steppers.
It’s basically a setup to add filter capacitors to the homing/limit switch wires to help prevent false triggers due to electromagnetic interference.
Never had a false trigger. Do i need to do that or is shielding enough?
It depends on your situation. I’m running with just shielded wires on my homing switches and haven’t had any problems. I also use soft limits so my switches are only active during the homing cycle.
@PhilJohnson How and where did you run the power supply to/from? its in the schematic but not in the pix
The PHYSICAL power supply. Not the wires lol.
Oops
Welllllll? Where is yours hidden?
Ah, separate panel?
