Here is my 1st and 2nd (current) iteration of my CNC-controller.
1x Arduino UNO
4x stepper drives, one for each stepper, two drivers share the Y input signal
(one driver is missing in this picture below)
1x Arduino UNO
I recently completed my own version of the Phil style controller. Keeping the wiring from turning into a rats nest is a bit of a challenge and I’ve still got some upgrades in mind.
Has anyone noticed increased noise problems with this style of controller?
If anyone is looking to do their own controller, Phil is about to release a Demon Arduino Shield which will take a ton of the wiring out of the equation. Visit his website to get in on the pre-order.
It looks like it’s just a grbl breakout board. Anything more to it than that? $38 seems a bit steep.
@FoxxFighter Looks like your version has low pass filters on the switches… How has it been working for you?
Hey
to be honest I never had any issues with noise. But I ran shielded cables. I throw the filters in because I read that so many people had problems and I didn’t want to run into this after upgrading.
Just ordered the boards and components you listed. Looks promising.
He’s releasing a shield in the next few weeks that gets rid of all the barrier strips and has built in active filters.
Barrier strips are $12 (not needed with Demon shield)
Capacitors and resistors are sold in bulk sets, about $10 per set. (Not needed with the Demon shield)
I built a demon shield before I saw this. It took hours to wire. (The demon shield has far less wiring).
I had to jumper grounds all over the place for the drivers. (The Demon shield eliminates jumpers).
You say steep. I say $29.99 well spent. I might even buy one to simplify my setup. His accessory connections are super convenient.
Forgot about the screw shield too… that’s another $20 not needed.
So you are saving a bunch of money and time with his shield.
It is a well designed product that will allow improvements by many users. Any negative comments will just be “sour grapes” comments IMO, made by those wishing they had thought of it first.
My comment was part of a question about the board. I think $38 for an Arduino breakout shield, with no components, is steep. I see you clarified that some inputs include noise filters. Any info on those? Simple low pass filters or opto-isolated? Do you know the values of the filter components?
My questions are out of interest (unfortunately, I seem to need to explicitly say that ). It looks like a well thought-out setup with his renders.
I only know that it is active, not passive. I believe that he announced that there are other options in the works including a switch to make adding a rotary easy. And other versions of different completions.
hello there, did you have one diagram to conec all those parts?
