The drawing for the clips show a 2.75 mm slot height and 7 mm slot width.
With a 3mm pitch you’ll probably need to open em up a bit.
@LarryM, what effect will using one driver for two motors have on the output signal? Would you suggest wiring the motors in series or parallel?
I wonder if the motors were wired in series, would one motor move before the other when a signal was sent. My thinking says yes, but it may be a very small amount - I have been known to think wrong most of the time though
Given it’s even possible to connect in series, you would probably have some propagation delay from motor 1 to motor 2. Might be minimal but in stepper world, it’d probably be enough to wreck havoc.
I think the bigger issue would be the drop across motor 1 though.
If you have the current limit set to the maximum for the stepper motor that you have and you have $1=255, the answer is a bigger motor.
Doesn’t affect holding power.
Easy to check.
I have three of these. Haven’t put them in a machine yet. (they are 76mm long)
The stepper drivers we have reduce current if they are not actively stepping. Before buying a new stepper, try turning up the current. Watch the stepper case temperature. It’s ok for them to run warm. Watch temperature during long runs in summer conditions. After a hard 12 hour run mine hit 142 F one time. Most of the time they are 30F above ambient. They are 3 amp rated and I have the driver set for full power. The higher the current setting the hotter the drivers will run. Make sure your drivers are well actively cooled.
Depends on the driver and its setup. Some do, some don’t.
The X-controller has this capability, but it can be enabled/disabled with a dip switch setting.
Try 2b stepping. I prefer my z at 4 micro stepping. I think 2a gives less power than 2b. 112 f is not hot.
Doesn’t change the holding torque, just the ramp up/down step size.
Think of 2A as a power drill and 2B as an impact wrench.
Same company sells on ebay, higher prices but free shipping.
Ouch! Mine wasn’t that much, but I ordered them a long time ago.
Phil, go back to the linked site - in the upper right corner click on the American flag. Then locate the motor.
Should be $20.50 with $7.07 (North Carolina) shipping.
Those are the motors I am running on X, Y and Z now.
The motion is incredibly smooth at both crazy high speeds and low speeds with plenty of holding power.
Does replacing the stepper motors with larger ones really improve the performance/behavior of the XCarve?
I did more then just motors, I think the combination of the steppers and the Gecko G540 controller has much better performance.
