Marine E.G.A
Just put together my X Carve and my first project i did this…i am floored by what this machine is capable of! i used a 1/16 upcut but and the depth is pretty deep…but in all its awesome!
Welcome to the club.
That looks great.
Very nice and happy carving.
Awesome and welcome
OOHRAH!
Looks good.
welcome. good first one.
… why does the Navy let Marines on board?
… Sheep were to obvious.
Great project. Looks great!
Thanks Zach for explaing the 2 step bit process…i figured it out and my 5 point stars i will use on my flags come out sharp! i use a 1/16 to rough it and a 1/32 to detail…thanks man!!
If you want them truly sharp, a V bit would be best. Any endmill is going to leave a radius in the points.
Robert…will a 60° v-bit cut a 1 inch star sharp by itself or would i have to follow up with a smaller type bit afterwards?
Yes, a true point (no flat) 60° v-bit will cut the points sharp. Depending on size, you may want to look at a two stage carve using an endmill (1/8" maybe) for the roughing cut and the v-bit for the detail cut.
