Masking for painting
What do you all use to mask your projects so that you can paint the carving portion?
I used painters tape. However, even the down cut bit managed to either lift or peel edges and small areas. I am looking for a good masking material for such projects. Your suggestions are very welcome.
Search for oramask here, should find the details you need…
