Can you share your gcode?
Or the Easel project?
File–>Share–>Share with Link–>SAVE
Can you do the following:
- go to the “Home Position” (really work zero)
- open machine inspector (ctrl+shift+D)
-In the console, type$#
-paste results here along with Machine Position and Work Position (screen shot might be easier)
Got the project…have you done anything with the electronics?
Can you also post your GRBL settings (send $$ through console)?
If you jog 3 inches to the right, does it actually move 3"? Check the same in the Y axis.
no movement from $# in the machine inspector
No homing switches?
How about the jog distance?
I do have homing switches, it does seem to move the proper distance
youre, right X is right, Y axis is moving too far
Did you home the machine?
When you send $#, can you make sure to get the G54 line from the console?
OK…send $$ and paste the values here. It’ll be a bunch of “$a = b” lines.
ok
$132=100.000
$131=790.000
$130=790.000
$122=50.000
its not letting me see more than just a few lines
Scroll down in the browser. Or click and drag to highlight.
ok
$132=100.000
$131=790.000
$130=790.000
$122=50.000
$121=500.000
$120=500.000
$112=500.000
$111=8000.000
$110=8000.000
$102=188.976
$101=40.000
$100=40.000
$32=0
$31=0
$30=1
$27=1.000
$26=250
$25=750.000
$24=25.000
$23=3
$22=1
$21=0
$20=0
$13=0
$12=0.002
$11=0.020
$10=115
$6=0
$5=0
$4=0
$3=3
$2=0
$1=255
$0=10
Looks ok.
Can you get a photo of the inside of your X-controller?
Specicically looking at the little switches here:
I made mine match what you had, I had 1 off, and it fixed it. thanks for babysitting me, I owe ya, if you come to TX I’m buying lunch!
Sweet! Glad you’re going now. I was about to give up and go to bed & let @HaldorLonningdal pick it back up whenever he gets up.
For reference, those dip switches set the microstepping for the motors.
The $$ settings are explained here, and I was specifically looking at the $100 & $101 (X & Y steps/mm).
The $# shows all offsets in the machine’s memory.
Not sure when I’ll make it to TX, but I’ll take you up on that. (Pulled my frozen door handle off my car this morning)
Good luck!
