And I wish I had the opportunity to take a shop class!
I am not sure but i think the 8.56" will make the center to tall. He wants the top of the pyramid to be only 1" tall. I could be wrong i uess i need to cut 3 and see. My wife says i should have taken typing and i think see is right.
Oops! I calculated for a pyramid with a square base.
Should be 5.01".
Hereās the correct formula:
No problem i just thought it sounded to tall.
Edited my previous reply with the correct value: 5.01"
I was thinking around 5" but was not sure. I thought i would cut them with a 90 degree v bit and they might be a bit easier to put together. Thanks for all of your help Neil and i will let you know how they turn out.
No problem. Iām curious how it turns out.
I wouldnāt do that as the angles are probably in the single digitsā¦have him sand them.
I figured there would not be much of an angle but i thought it might help. thanks
Will try for this one surely.
