Maximum size material
Hello guys!
Doing little research before ordering first x-carve and I can’t figure out about the maximum size material that can be carved? Here what I found on FAQ and below a picture online support send to me…
An assembled 500mm x 500mm machine has a maximum cutting area of 300mm x 300mm x 65mm (from the bottom of the x-carriage to the top of the waste board).
An assembled 750mm x 750mm machine has a maximum cutting area of 550mm x 550mm x 65mm (from the bottom of the x-carriage to the top of the waste board).
An assembled 1000mm x 1000mm machine has a maximum cutting area of 800mm x 800mm x 65mm (from the bottom of the x-carriage to the top of the waste board). The open frame configuration allows for some longer size materials to fit into the machines.
If you take a look at the picture it’s 250x250 etc…
Now it’s more clear!
Thank you, AngusMcleod.
