It maintains the aspect ratio of the image. If you set the width, it will change the height, and vice versa, to keep the image from squashing.
There’s also an origin offset value you can enter if you want to shift the location of the output around. Most likely you’ve given it an image that contains a lot of blank space - There’s no way it would just choose to move it 5" to the right for no reason.
