I hope to get a picture soon if it ever finishes lol
and oh heck yeah man well heck i even ran my x-carve at 180ipm in somethings but I think 200ipm is about the limit for the x-carve machine would literally shake itself apart doing carving like this lol maybe
its funny I complain that I can’t go 3500ipm like some cnc routers can do cutting cabinet nests
I played with a lot of 1/4" thick 2 color HDPE last week with the new Carvey at work (yay, new toy!!!). I found that it has a topcoat thickness of about .050-.060". I asked customer success about the 2 color acrylic, and they said the topcoat was .005".
oh yeah I see what your saying I didn’t paint that its just that white faced hardboard they sell at lowes so its already white on the outside and black on the inside
so if I use that material I should be able to just invert the image in the software and it should come out better I am thinking
No one has posted this problem, but …
I am using 500mm XCarve with GRBL 0.9j and carved a “dots” picture that went nicely until Microsoft decided it was time to update Windows, so the bottom corner is missing. I tried a “lines” version of the same image, but GRBL threw an error 24 right at the start, and the machine went off into space. Some poking around found that GRBL doesn’t like the “G49 G80” commands in the initialization of the file; removing those two commands solved the problem. Also if you’re using a DeWalt, edit the “S30000” to read “S12000” or your spindle start may be ignored.
Many Thanks to Jason Dorie for a fabulous program!
thanks why I use dedicated computers for the cnc machines that are not connected to the internet and have all the update settings turned off the only thing the computer should be doing is running the machine nothing else
If you look at the two pictures you posted, the software is showing you what the surface color of your material is on the border of the image. In the top picture, the border is black, showing that the program is configured to make light cuts in dark material. If you click the invert button, you get the bottom image, showing you dark cuts in light surfaced material.
