Hello,
I am looking for information on drilling holes with a drill bit rather than an endmill using the xcarve. I am using Estlcam as my controller/CAM which has a drilling feature, where it pecks at the hole to clear the chips. I can’t seem to find the right name for bits that have a standard 1/4"/1/8" shank size and a variety of drill size diameters. I know of those small 1/8" shank dremel bits used for drilling holes for PCBs, but I’m thinking larger scale such as a 1/4" drill. Most, if all my drilling will be in wood.
Thanks,
Zac
There is always the step bit option, which works well for making lots of different hole sizes as long at the material isn’t too thick.
I think dowel drill is the term you are looking for. Or these they go to .25 inch.
http://www.ebay.com/itm/Carbide-Drill-Bit-Variety-Set-Super-Value-CNC-PCB-Dremel-Hobby-Models-C7-/151254836552?hash=item23377da548:g:joYAAOSw~CRTpD18
If you can get access to a lathe you could gut a electric drill and have the shaft attached to the chuck turned down to .25.
Drill Mills would work. I order then from grainger. They are basically pointed endmills.
They are good for pick drilling, but also Chamfer ING edges.
Oh wow, I didn’t know that style would go that big, Thanks for the link!
Depending on material and hole size you’re sometimes better off with the “Helical Drill” function and a small endmill, especially for large diameters.
- The issue with drill bits is the lower rpm limit of the router or spindle motor -> it is usually just too high for large diameters.
- Drill bits require very low rpm compared to endmills -> if rpm is too high the bit will get very hot and cause all sorts of trouble like burned edges, molten material or just gets dull and breaks.
- A helical drill on the other hand uses an end mill with smaller diameter than hole size and cuts in a helical / spiral fashion. This causes much less friction and heat and may also save you some tool changes:
Peck drilling:
- Small diameter holes
- Deep holes
- Very good roundness
Helical drill:
- Large diameter holes
- Much more tolerant in terms of feeds rpm
That’s exactly what I was thinking…
Thank you everyone for all the information! I kinda got the idea when I watched someone at my work use a manual mill to drill some holes. He just threw in a chuck adapter, used a normal drill bit and basically used it like a drill press. But yes, on manual mills you can go much much slower speeds, which he adjusted when he was drilling the holes.
@ChristianKnull
I have been using your program for some time and to be honest I never thought of using the drill feature as I thought it was made more for threaded holes or drilling with drill bits (pecking). I have always been using the “Inside” feature to drill out holes. Is there much difference between the two features, inside vs. helical drill?
There are 2 main differences between the “inside” and “helical drill” function
- The “inside” function does not necessarily clear all material inside the hole. If tool diameter is smaller than half hole diameter a core will remain that may cause trouble once it loses contact to the rest of the material. The helical drill removes all material inside the hole no matter the diameters.
- The “inside” function plunges deeper step by step while the helical drill goes deeper continuously. The latter improves the roundness of the hole and works a bit faster.
Thanks for the Estlcam tip!
Are you able to help with some settings for communicating to the X-Carve machine?
Thank You in advance,
Rush
