I notice the x carve is not starting at the 0 side it starts at the oposite side also the carve is backwards and upside down. It starts on the opposite side of the y axis
I am pretty sure that would be a $2 setting. Can you type $$ into the console and see what that setting is?
Sounds like your X and Y axis are reversed.
During setup, did you test and verify each axis direction? There is a specific UI for just this.
$2 is at 0. I tried switching it however did now work on 3. I did test and all is going the correct direction.
