I would vote to keep machine step up as basic as possible. Custom builds should use the advanced tools to set parameters. ACME vs threaded is confusing for some of us.
Would be perfect if at the beginning of setup it asked for what type of user you are.
Beginner wich will bring you to the bare minimum options
Or advanced where there is more options to play with.
Makes it easy for both worlds
I think that the advanced option during setup is good or give us the ability to change any of the settings under the advanced tab. I don’t like having to run through the setup after I have all of my settings correct and have tweaked each axis for precision movement.
Great idea.
