More tool bit passes
Hello,
I am unsure if this is a limitation in G-Code (I would think not),
But can we have the option to add multiple (as many as we’d want ideally) tool passes instead of just a “Roughing and Detail” pass?
I understand there is a workaround with duplicating the work, then setting the roughing pass as the bit from before, but it seems like this should be an unnecessary step.
I have the same request for more tools. as your request hasn’t been answered, could I ask what is the work around? i’m part way though a complex carve and I’m not prepared to to have the machine running for hours. I’ve changed to the third (smaller) bit and it wants to run the whole program again.
Thanks.
Hi Wayne :wave:
The method (workaround) to get more control of what tool us used where for a carve is achieved by using multiple workpieces (the bottom panel) and running each additional bit as a seperate carve. Kinda like whats shown in this tray video
Brilliant, thank you.
