Need some help.
Im carving stars for the union on a flag, and I’ve noticed that a lot of the stars get a little curvature to the straight sides. I’m cutting .25” using a 90 degree bit at .06 per path. Any help would be appreciated.
Need some help.
Machine not rigid/firm enough.
Tried doing the same in MDF which do not have fiber direction?
Thanks ! When you mean machine do you mean belt tension / v heels? Or are the table on which I have the machine is not stable enough?
With “Machine” I mean the entire system as it all have impact.
I am seeing surface imperfections and bleeding of the blue color.
