Multi-piece project in Easel
I have a Carvey and this will be my first time designing my own project using Easel. I want to make a sign that is 11inx18in. Since that is larger than what carvey can do i need to break it up into sections and then put it together. Is there a way i can design the whole sign in easel and then it will carve the necessary parts into each piece of wood? Hopefully this makes sense! Any input would be helpful, Thanks!!!
What Angus said, just make sure you drill 2 holes on the outer perimeter of your work, so you can easily shift from 1 to the next. At least that’s how I’d do it.
